Hydraulic help
/ Hydraulic help #1
nyen0004
Morewood, Ontario, Canada
John Deere 2320
Hey everyone I am planning on building a dump cart for my JD2320. I want to make it hydraulic dump, and not knowing anything to do with hydraulics I would like you guys help to figure out what size of cylinder to use. I thinking on a 4 x 6 trailer. Any info would be great. Thanks
/ Hydraulic help #2
There are too many variables to just say this size will work.
Will it be a scissors lift or straight lift?
What pressure will it operate at?
What distance from pivot point?
etc..
/ Hydraulic help
I am thinking just a straight lift, The spec for my tractor say the hydraulics run at 2400psi. AS for pivot point I dont know that is why I'm asking everyone. I there some kind of formula to figure pivot point/cylinder size/etc?
/ Hydraulic help #4
Straight lift requires less figuring. For cylinders force = area time pressure.
example: 4 " bore cylinder has 12.5 square in area times 1000 PSI = 12,566 lbs of force or at 2000 PSI you have 25,133 lbs of force. Figure a yard of wet dirt is 2500 - 3000 lbs you can in theory lift 8 + yards. If your pivot point is at the opposite end of a 6 foot trailer with the load even distributed you could in theory haul 16 + yards.
Never use max system pressure to figure cylinder forces unless you are using a single acting cylinder or moving very slowly. There will ALWAYS be line losses on tractors. Generic rule of thumb I use 85 - 90 % of max pressure should give you a close estimate on the actual force you will be able to achieve while the cylinder is moving at a reasonable speed.
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
2018 Club Car Carryall 1700 4x4 Diesel Utility Cart (A61572)
2018 Club Car...
(20)PIECE UNUSED SDLANCH HIGH END 2M RATCHET STRAP (A64280)
(20)PIECE UNUSED...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
