Hydraulic help
   / Hydraulic help #1
nyen0004
Morewood, Ontario, Canada
John Deere 2320
Hey everyone I am planning on building a dump cart for my JD2320. I want to make it hydraulic dump, and not knowing anything to do with hydraulics I would like you guys help to figure out what size of cylinder to use. I thinking on a 4 x 6 trailer. Any info would be great. Thanks
   / Hydraulic help #2
There are too many variables to just say this size will work.
Will it be a scissors lift or straight lift?
What pressure will it operate at?
What distance from pivot point?
etc..
   / Hydraulic help
I am thinking just a straight lift, The spec for my tractor say the hydraulics run at 2400psi. AS for pivot point I dont know that is why I'm asking everyone. I there some kind of formula to figure pivot point/cylinder size/etc?
   / Hydraulic help #4
Straight lift requires less figuring. For cylinders force = area time pressure.
example: 4 " bore cylinder has 12.5 square in area times 1000 PSI = 12,566 lbs of force or at 2000 PSI you have 25,133 lbs of force. Figure a yard of wet dirt is 2500 - 3000 lbs you can in theory lift 8 + yards. If your pivot point is at the opposite end of a 6 foot trailer with the load even distributed you could in theory haul 16 + yards.
Never use max system pressure to figure cylinder forces unless you are using a single acting cylinder or moving very slowly. There will ALWAYS be line losses on tractors. Generic rule of thumb I use 85 - 90 % of max pressure should give you a close estimate on the actual force you will be able to achieve while the cylinder is moving at a reasonable speed.
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2019 KENWORTH T680...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2017 TAKEUCHI TL12V2 SKID STEER (A52705)
2017 TAKEUCHI...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2017 FREIGHTLINER...
