Hydraulic heat
/ Hydraulic heat #11
Mikeman1 the grease fitting is on hyd pump and u need to take Allen head screw out from below fitting on side of pump. Remove bolt and grease till grease comes out of hole then reinsert the Allen head
/ Hydraulic heat #12
My 2555 runs around 200 on a 90° day bush hog for 12 hrs constant. My oil cooler swelled and started to leak. Got it replaced and a bypass retro to prevent too much pressure. They have service bulletin and it's covered even after warranty. Fix as Fail though. But my fluids ran 30 plus degrees hotter before the repair
/ Hydraulic heat #13
great info, forgot to get back to, yes i found the allen head and applied grease until it came out the allen hole. thanks again.
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
