Hydraulic Hay Spears
   / Hydraulic Hay Spears #1
astropilot
I am Looking for infomation and comapanies that make Hay spears that works like a forklift. The only one I have found is http://www.brushboss.com/hilift.html, but I think there are more out there. Thanks from Kentucky
   / Hydraulic Hay Spears #2
Are you wanting for the fork lift or the high lift part for hale bales or both?
   / Hydraulic Hay Spears #3
You need a large heavy tractor 75+ HP with a 4wd to safely use these highlifts. A 35 HP tractor has the hydraulic pressure and seems large enough but I've seen guys turn the tractor over because they did not have enough weight. If you just want to put a round bale on a trailer then look at the Fred Cain Style Scissor lifts.
   / Hydraulic Hay Spears #4
The Fred Cain high lift spear was what I was thinking /forums/images/graemlins/grin.gif if he needed it for high lifting round bales.
   / Hydraulic Hay Spears #5
How high can one of these lift a bale?
Fred
   / Hydraulic Hay Spears #6
The height is determined by the size of the tractor they are mounted on. They will set a round bale on a normal wagon. if you want to stack hay, this loader will stack hay on top of other bales if you position the bale in the center of two bales. The #1 use is for people that want to move round bales on standard 4 tire wagon and do not want to invest in a FEL.
   / Hydraulic Hay Spears #7
Hey CCI, I believe I emailed you a week ago about this hi-lift & a 5 wheel rake. Never heard from you. Did my Hotmail account not pick up your reply?
--->Paul
   / Hydraulic Hay Spears #8
I apologize please resend the email. We get 100+ emails a day and likely I missed it.
Mark
   / Hydraulic Hay Spears #9
Welcome to TBN--Where are you located in Ky? We have 2 stores in central Ky, come by and visit either location and we will show you what we have--We have used the Fred Cain Lift for years in feeding our cattle and may be able to give you some firsthand experiences and info-Ken Sweet
Sweet Farm Equipment LLC
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
GREENLEE 555C ELECTRIC CONDUIT BENDER (A51247)
GREENLEE 555C...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
Electric Mobility Scooter (A51694)
Electric Mobility...
200387 (A51247)
200387 (A51247)
2025 CFG Industrial MX12R (A50123)
2025 CFG...
