Hydraulic Hay Spear Attachment for John Deere 870
   / Hydraulic Hay Spear Attachment for John Deere 870 #1
mwaine
I have a JD 870 compact utility tractor with a hay spear attached to the FEL. Wondering if there's a hydraulic spear available. Hoping to shift the weight of the heavier round bales to the back. A bit front end heavy. Thanks
   / Hydraulic Hay Spear Attachment for John Deere 870 #2
There are readily available 3PH Cat 1 hay spears... is this what you're asking about or am I misreading your question?
Is your FEL spear (singular, pair or tripple?) its own attachment or bolted to a bucket?
   / Hydraulic Hay Spear Attachment for John Deere 870 #3
Why do you need it to be hydraulic?
I believe all those are 3-pt attach spears. I'd like to be able to remove the FEL and attach the spear assembly directly to the FEL mounts which will hopefully not make it as front-end heavy and still have the ability the raise, lower and tilt. And they are triples.
I'd like to be able to remove the FEL and attach the spear assembly directly to the FEL mounts which will hopefully not make it as front-end heavy and still have the ability the raise, lower and tilt. I'll try to add pictures of my current setup. Thanks
   / Hydraulic Hay Spear Attachment for John Deere 870 #7
So you want to remove this:
And build something lighter that will do the same thing with your bale spear?
What size bales and how heavy?
   / Hydraulic Hay Spear Attachment for John Deere 870 #8
I have a FEL 2in1 attachment (JD FEL QA System). The 'back stop' is attached to the FEL and I have the bale spears mounted via the tubular steel installation pieces. The beauty of this is that I can swap out the bale spear attachment for a pair of pallet forks.
   / Hydraulic Hay Spear Attachment for John Deere 870 #10
A 870 weighs 2,500lbs. Even properly blasted that's sketchy for lifting large bales. I've done it on my former L3200 (which weighs the same) with loaded rears & heavy 3pt ballast mounted way back. Never again after helping a neighbor move that load of hay.
You'd be fine with a 3pt bale spear, but that's sketchy on a loader on that small of a machine. That video shows a JD 5 series machine which is well over double the weight of a machine for a reason.
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A53472)
2009 Ford F-650 24...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
