Hydraulic guestion
   / Hydraulic guestion #1
JWD1312
CHEYENNE, WYOMING
Kubota 7510
I need a single acting cylinder about 40 inches retracted, 4 inch piston, 2 inch rod, 30inch stroke , for my dump trailer. I'm going to use a 12 volt power unit(single acting with solenoid valve) I can't seem to find the right size single acting cylinder anywhere.
Can I use a double acting cylinder ( I can find the right size) and use it as a single acting cylinder with out any problems.
   / Hydraulic guestion #2
Have you tried Surplus Center?
They have single and double acting cylinders that are pretty close to your specs, like this
or this
These may not be exactly what you need (one is a center trunion mount), but they have a pretty good selection and the prices are resonable too!
I believe it is possible to use a DA in a SA implementation, you just have to install a bleed valve in the unused port. If I'm wrong here, some one please correct me.
   / Hydraulic guestion #3
You can use a DA as an SA, just get a vent plug for the unused port. I believe Northern Tool still has them.
   / Hydraulic guestion #5
I have a single action cylinder at home. The length is going to be close but I don't the the diameter is that large. I will check this afternoon.
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
Kubota BX2230D (A47384)
Kubota BX2230D...
2016 Ford Explorer...
