Hydraulic front loader on belarus 572
   / Hydraulic front loader on belarus 572 #2
Jerky points towards pump not getting oil.
First things I would check are:
hydraulic oil level,
oil condition, I.e. is it milky colored from moisture ingression or foamy from air?
Is there a suction screen on this model? If yes check to see if it is clean?
Is there a inlet filter? If yes when was it changed last?
Where is the pump mounted? If any external inlet lines double check to make sure that none of the rubber hoses are cracked / weather checked. Check all of the connections to make sure that something has not worked lose over time.
2019 Kubota F3990 72in Commercial Mower (A50322)
2019 Kubota F3990...
(2) Galaxy 180/95-14 (2) 11.2-24 Tires and Rims (A50120)
(2) Galaxy...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
