Oil & Fuel hydraulic fluid
/ hydraulic fluid #1
sheldon1968
2022 Kioti CX2510
Can anyone tell me where the hydraulic fluid is checked and added in a Kioti CX2510....I think I found it but just not 100% sure.
Thanks in advance guys.
sheldon pinsent
/ hydraulic fluid #2
You check the fluid using the dipstick by your left heel as you sit in the tractor.
I was going to say that you add fluid on that orange fill port in the picture, but the manual shows otherwise. I guess you kind need to see if you have that fill plug they show in the manual or if that was changed.
/ hydraulic fluid
LOL....Mine is a 2022 but I do not have a dipstick or anything like that inside the cab.....Its the Hydraulic Fluid dipstick Im looking for though not transmission
/ hydraulic fluid #4
Transmission and hydraulic fluid is the same on most tractors, including this one.
/ hydraulic fluid
ok awesome thanks. Just spoke to the dealer and he is sending me the proper fluid for the Kioti
/ hydraulic fluid #6
I was confused at first as well, as the filler tube merely says "oil".
There is no dipstick, just the sight glass as shown on the diagram ptsg put up.
The diagram leaves a lot to be desired, though. I don't know about the HST, but on the manual, the sight glass is down below on the bucket control side.
