Hydraulic Fluid
   / Hydraulic Fluid #1
Jeep681
LS XG3037H
I have a 2016 LS XG3037H Tractor and would like to know what Hydraulic fluid others are using? What is your recommendation.
   / Hydraulic Fluid #2
See your owners manual. It probably calls for premium tractor fluid. Tractor fluid has additives for smooth operation of wet brakes and clutches (i.e. the PTO clutch) that are not in hydraulic fluid.
Tractor Supply carries Mobil's premium tractor fluid which worked well my Branson.
   / Hydraulic Fluid #3
If the tractor has a hydrostatic transmission (HST) go by the recommendations in your owner's manual. If it's a gear transmission use tractor fluid as Eric recommended.
   / Hydraulic Fluid #5
I use John Deere Fluid from North 40, Has a "J20" application. I use it in my Massey 165 and JD Dozer, trans and hydraulic. Works very well for me and no performance problems with thousands of hour on the machines.
Metal Rolling Stairs (A51573)
Metal Rolling...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2023 Bobcat E32i Mini Excavator (A51573)
2023 Bobcat E32i...
