Hydraulic Fluid
   / Hydraulic Fluid #1
Jeep681
LS XG3037H
I have a 2016 LS XG3037H Tractor and would like to know what Hydraulic fluid others are using? What is your recommendation.
   / Hydraulic Fluid #2
See your owners manual. It probably calls for premium tractor fluid. Tractor fluid has additives for smooth operation of wet brakes and clutches (i.e. the PTO clutch) that are not in hydraulic fluid.
Tractor Supply carries Mobil's premium tractor fluid which worked well my Branson.
   / Hydraulic Fluid #3
If the tractor has a hydrostatic transmission (HST) go by the recommendations in your owner's manual. If it's a gear transmission use tractor fluid as Eric recommended.
   / Hydraulic Fluid #5
I use John Deere Fluid from North 40, Has a "J20" application. I use it in my Massey 165 and JD Dozer, trans and hydraulic. Works very well for me and no performance problems with thousands of hour on the machines.
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
EZ-Go Golf Cart (A51573)
EZ-Go Golf Cart...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
