Hydraulic Fluid Smell when Using FEL?
   / Hydraulic Fluid Smell when Using FEL? #1
robertwhite
Got a new to me, low hour CUT and when I used the FEL today, I kept smelling hydraulic fluid (gear oil). Since I have not used this tractor or the FEL before, the question that of course immediately comes to mind is whether this is normal?
There are no leaks and the temp needle is exactly between the dots on the gauge. FEL worked just fine, but I sure would feel better if I knew the smell was normal (if not, it is still under warranty)
   / Hydraulic Fluid Smell when Using FEL? #2
What kind and model of tractor do you have. This may be normal for some models.
Best guess without knowing model is that the breather for hydraulic reservoir is situated in such a way that you are getting the fumes from the oil circulating.
Roy
   / Hydraulic Fluid Smell when Using FEL? #3
Roy
Agree, this was addressed on another thread, but I don't remember which one.
   / Hydraulic Fluid Smell when Using FEL? #4
robertwhite,
You are describing two different things. You said you smell "hydraulic fluid (gear oil)". Gear oil smells nothing like hydraulic oil (to me). If you are smelling hydraulic oil, it is either from a leak or just that the system is "breathing" through the vent because it's hot.
If gear oil, it is coming from somewhere other than the loader/hydraulic system, like the front axle, mower gearbox, or something like that.
   / Hydraulic Fluid Smell when Using FEL? #5
I've noticed that on all of my Kubotas at one time or another. The UDT and SUDT I use does have a distinctive smell similar to gear oil. That's not surprising since it's used in the transmission.
Over time, none of my tractors have experienced any noticeable fluid loss. I think you're probably OK with the new CUT.
Bob
robertwhite,
You are describing two different things. You said you smell "hydraulic fluid (gear oil)". Gear oil spells nothing like hydraulic oil (to me).
It is a hydraulic fluid smell.
Roy
You know, when I think about it, the vent hole (which is on the end of the filler tube) is situated right in back of the seating area. Probably is just that.
Tractor is a Bobcat CT335
   / Hydraulic Fluid Smell when Using FEL? #8
Super UDT in my Kubota smells slightly "sweet" when I work the FEL to any great extent. Gear oil is generally loaded with high sulfur extreme pressure additives and smells like -- well, sulfur. Hydraulic fluid odor from FEL use is normal as far as I can tell. If this is not true I hope someone here can let us know.
   / Hydraulic Fluid Smell when Using FEL? #9
When I get my L4400HST warmed up and use it I can smell the SUDT and from what I have read it is normal.
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
2021 JOHN DEERE 624 P-TIER WHEEL LOADER (A52705)
2021 JOHN DEERE...
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
2013 MACK PINNACLE (A53843)
2013 MACK PINNACLE...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
