Hydraulic Fluid Restriction
/ Hydraulic Fluid Restriction #1
NCMau
NC
MF 202/Ford 8N
I would like to slowdown the loader ram cylinders in certain situations. Is there a practical fixture available for this purpose that can be used when there is a need, some like a needle valve?
The purpose of the ram slowdown would be to get a more accurate control of a bucket attachment I made for a limb trimmer. The attachment consist of a 9ft pipe with a trim saw at the end.
/ Hydraulic Fluid Restriction #2
I am not aware of any valve you can put in the line. I just go lighter on the control and or reduce rpm for fine control.
J.J. if I would decide on the needle valve, which one would be best for my application, single or dual direction?
/ Hydraulic Fluid Restriction #5
It depends on whether you want fast action both ways or slow in one direction.
You might want slow cutting and fast retract.
The one valve will provide slow in both directions or fast in both directions. You adjust for the speed you want.
Just to be clear J.J., if I would use a dual direction valve, would I use just one needle valve on one of the control valve pressure ports?
/ Hydraulic Fluid Restriction #7
Yes, that is correct.
I would use the valve in the Meter-out circuit.
Install the flow valve at the valve extend work port.
This will give you a control flow to the extend on the cyl and retract if you the controlled flow both directions.
You might want the other valve if you want slow extend and fast retract.
Thanks.
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
2015 John Deere Z950M 72in Zero Turn Mower (A59228)
2015 John Deere...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
