Hydraulic Fluid question
   / Hydraulic Fluid question #1
Danno1
Veteran Member
Mass, Northshore, Merrimack Valley
B6100DT
I'm due to change the hydraulic fliud in my FEL and BH very soon. I have a 1979 B6100 4WD, regular old gear transmission, subframe mounted BH (B670) and B219 FEL. These each have their own separate dedicated hydraulic systems. No 3pt hitch installed.
I see a lot of oil acronyms around here (UDT, SUDT, etc). My manual states use 10W-30 for the FEL and 10W-40 for the BH.
Am I to assume this means use regular motor oil ??? Any other tips or tricks I should be aware of?
   / Hydraulic Fluid question #2
I think the oil rec's have a lot to do with the age of that machine. i have alot of CAT equipment that specs 30w or 40w eng oil int he trannies and hyds.
Most of those specs either get updated or superceded over time ( Probably some don't ). i bet if yuo called a dealer and told him what model fel/BH you have.. assuming he would answer the question.. he'd probably tell you to use whatever the currecnt kubota oil spec was.
I know if you call a CNH dealer and ask what hydro oil to put in a 1939 ford 9N they will tell you the new 134 type oil ( aka UTF ).. etc..
Soundguy
   / Hydraulic Fluid question #3
Here's what my Chek-Chart manual calls for for the B6100
Transmission, differential and hydraulic system - SUDT
Front differential - 80W GL-5
Bevel gear housings - 80W GL-5
Steering gearbox - 80W or 90W GL-5
So it looks like the modern fluid they are calling for is a UTF oil in the majority of the system.
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
UNUSED FUTURE MINI EXCAVATOR HYD TILT BUCKET (A51244)
UNUSED FUTURE MINI...
2013 Infiniti JX35 SUV (A50324)
2013 Infiniti JX35...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
