Hydraulic fluid looks like caramel - water contamination?
   / Hydraulic fluid looks like caramel - water contamination? #1
zanfirico
Caton, NY
New Holland TC25D
Long time reader-first time poster. i searched a little but couldnt find a real answer to my fluid conundrum. Yesterday I was changing filters, and when I went to change the hydro filter on my Woods 7500 backhoe, and the fluid coming out (I didn't drain first, that's a different problem :0 ) was brownish yellow, opaque, and wholly terrible looking. After searching a bit, I am assuming the fluid is contaminated with water, but I can figure out where the water is coming from. It's a pto driven pump system with its own reservoir, and the only opening I know of is the dipstick/filler cap which protrudes upward at about a 45deg. Angle and has a cap with a foam filter covering it. The hoe had been in use the last week and had been working fine, but when I replace the oil today, I'd like to protect it going forward.
Any ideas? Also, will the remainder oil I the cylinders and lines be a serious problem once its diluted down with several gal.s of new fluid?
Thanks ahead of time.
   / Hydraulic fluid looks like caramel - water contamination? #2
Yea that's water alright. You store this outside uncovered?
   / Hydraulic fluid looks like caramel - water contamination? #3
Likely the water is from condensation in the tank. It may be water tight but it isn't air tight. Storage outside accelerates the condensation from nightly cooling where it will suck in warm moist air that condenses the water vapor. This is the main reason for oil changes in hydraulics in that the oil rarely "wears out" but does get contaminated. Just change it all out on a regular basis as per mfg. directions and you should be good. Inside storage would prolong the time between changes to some extent. Sampling the oil to check for water contamination would be a good thing to do if you have access point large enough to do this.
   / Hydraulic fluid looks like caramel - water contamination? #4
If you can't find the leak, cover the tank with tarp or something.
QD's or cyl might ingest water when hyd circuit cools down because there is a vacuum created and will either suck in air or water.
I do indeed keep it outside, and though I realize condensation can form, I guess I didn't realize how much of an effect it would have on the oil. Would anyone recommend some sort of desiccant filter on the fill hole, in place of the cap?
I will also try the tarp idea, just in case. What's one more tarp in the backyard? I think I even have one that's NH blue :)
2021 Jeep Wrangler 4x4 SUV (A51694)
2021 Jeep Wrangler...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
JOHN DEERE 661R LOT IDENTIFIER 97 (A53084)
JOHN DEERE 661R...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
