Long time reader-first time poster. i searched a little but couldnt find a real answer to my fluid conundrum. Yesterday I was changing filters, and when I went to change the hydro filter on my Woods 7500 backhoe, and the fluid coming out (I didn't drain first, that's a different problem :0 ) was brownish yellow, opaque, and wholly terrible looking. After searching a bit, I am assuming the fluid is contaminated with water, but I can figure out where the water is coming from. It's a pto driven pump system with its own reservoir, and the only opening I know of is the dipstick/filler cap which protrudes upward at about a 45deg. Angle and has a cap with a foam filter covering it. The hoe had been in use the last week and had been working fine, but when I replace the oil today, I'd like to protect it going forward.
Any ideas? Also, will the remainder oil I the cylinders and lines be a serious problem once its diluted down with several gal.s of new fluid?
Thanks ahead of time.
