Oil & Fuel Hydraulic Fluid Level - L3400
   / Hydraulic Fluid Level - L3400 #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I know... this will sound like the dumbest question you've ever heard asked, no doubt. But - I'm bumfuzzled. So, I'd rather look stupid than broke down.
I had a Top & Tilt added. And now I have no idea as to how to check the hydraulic fluid level for the rear hydraulics. If I pull the return line cap, how far down should the fluid level be?
Can you tell me where to check the fluid level, and how to tell if there's enough or not?
Thanks,
Jim :confused:
   / Hydraulic Fluid Level - L3400 #2
Do you have a sight glass on the rear axle area or a dipstick?
   / Hydraulic Fluid Level - L3400 #3
Thanks,
Jim :confused:
There should be a sight glass on the side of the transmission by one of your feet if you are sitting on the machine. I think it is by your left foot...but dont quote me on that.
Adding a TNT shouldnt require any additional fluid. Those cylinders arent going to use that much. Maybe a half gallon at the most if you feel like adding a little for peice of mind.
Thanks LD1. I didn't realize that the level in the sight glass accounted for all hydraulic fulid levels.
I did find that little hidden sight glass once. But like you implied, that sucker hides from me :) Next time I find it I'm going to paint a white circle around it!
I'm suspecting that I've been overfilling. Not good.
   / Hydraulic Fluid Level - L3400 #5
l3200 has a sight glass on left side near clutch petal- lousy engineering -should have a dip stick but lets not go there- anyway sight glass should show fluid half way up the glass=kinda looks like a bubble on the top-check it cold--------------good luck ---jimbo
   / Hydraulic Fluid Level - L3400 #6
my dealer installed a dipstick on my L3400 not long after i purchased, it was in the shop for something and now i can't remember why they did it but think it was due to some TSB.
Thanks for the clue Jimbo. FINALLY found it (again). On the HST there's a half-moon cutout on the center console on the left side, halfway between the front and back.
...yeah, I put a nice label on mine. Unfortunately, I (as I suspected) have over-filled it. Fluid completely covers the sight glass and is foamy. And I'm also seeing a few drips of hydraulic fluid under the tractor. Should I drain some out? Or leave it be and let it self-level?
Not trying to redirect the blame, but the dumb-*** dealer showed me how to check the level. Unscrew the return line cap, stick my little finger in to the first joint. Fluid should touch the end of the finger. BONK! BONK! That's overfilled. Now that I've labeled the sight glass location, I'll keep it at the proper level from here on.
I blame myself for listening to the "salesman" based on the quality of parts and labor that they supplied on my top & tilt insall. Pathetic work and substandard parts. And I'm being kind in that description. This L3400 was my second tractor that I bought from those monkeys. Mark it as my last.
   / Hydraulic Fluid Level - L3400 #8
You're better to drain some out. I'd recommend putting a bucket under one of the drain plugs, parked on a truly level spot, and slowly let some drain until you can see the level in the glass.
Sean
   / Hydraulic Fluid Level - L3400 #9
Sean
i agree with sean------park it at a level spot, check it cold, drain it until its at right spot on sight gage-you don't want to blow a seal because you overfilled- good luck------jimbo
Got it; thanks. I'll do that this morning before, hopefully, I do more damage.
Jim
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
