hydraulic fluid leak
   / hydraulic fluid leak #1
football
Addison,Al
2030 jon deere
I have a 1977 john deere 2030 , Hydraulic fluid has started leaking out of the hydraulic pump vent line with engine off whats going on? This has just started ,haven't been using tractor much but loader is strong and power steering good, seems to be no problems ,pump was replaced in March 2015 also filter and fluid.
   / hydraulic fluid leak #3
Hey football, not sure what your problem is, I grew up driving 4030s but never had that problem (usually the opposite, could not keep oil in it), but wanted to give a shout out for Addison, AL. I grew up in Winston County. Welcome aboard, someone on here should be able to help you.
BTW- is your main sump level good?
   / hydraulic fluid leak #4
Welcome to the forum. :welcome:
I'm going to move your thread over to the John Deere section to see if we can get you some answers.
   / hydraulic fluid leak #5
:welcome: to TBN
Look to see if pump drain line is pinched together(kinked).
not sure how drain line connects ,does it go on small elbow on pump then back up to the reservoir?
   / hydraulic fluid leak #7
not sure how drain line connects,does it go on small elbow on pump then back up to the reservoir?
Yes that's correct line attaches to 90° elbow(parts key 9)
Thanks thought I was correct, but couldn't understand why it had not leaked before.
   / hydraulic fluid leak #9
If it leaks, the line must be cracked. If it leaks while running, then the internal shaft seal could be bad. That line is there to relieve excess pressure from behind external seal to keep it from blowing out.
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2005 International 8600 Hydro Vac Truck (A53117)
2005 International...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
