Hydraulic Fluid leak at quick coupler connection
   / Hydraulic Fluid leak at quick coupler connection #1
Osconda
Texas, Williamson County (aka Texas Hill Country)
New Holland TC55DA, delivered 05/25/2005
I installed some quick coupler to my rear SCVs on my tractor and I'm getting some fluid leakage where the quick coupler screws on to the hose. What should I be using to help seal up the threads when I install the couplers? Can I use the teflon type tapes used on plumbing? Looking for something readily available.
   / Hydraulic Fluid leak at quick coupler connection #4
I had trouble with one leaking threaded fitting just like you are seeing. Teflon tape did not make a long-lasting seal. I ended up using "Loctite PTFE/Anaerobic Pipe Thread Sealant For SS Threads, #567, 6-ml (.2-oz) Tube". Cost was around $4.00. McMaster-Carr is a good on-line source (www.mcmaster.com).
This stuff worked! No leaks a year after the fix. I think that there is enough sealant left in that .2 oz tube to fix a couple of dozen more hydraulic leaks.
Lou Braun
   / Hydraulic Fluid leak at quick coupler connection #5
For more discussion on this (if you want it) check the archives using the search feature. I know from experience there's plenty of posts on this topic. I have personally used liquid teflon with good success...
Good luck!
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
