Hydraulic fluid in plastic milk jugs ?
   / Hydraulic fluid in plastic milk jugs ? #1
Rocksprings
Rocksprings Tex.
Bota L2800 HST
I am saving my one gallon plastic milk jugs to transport used oil and hydraulic fluid to the recycle center. I know that gas will eat some plastic up but will they be safe for oil and hydro. fluid ?
   / Hydraulic fluid in plastic milk jugs ? #2
Safe.
I wouldn't fill them real full, and be careful when transporting so they don't/can't tip over.
   / Hydraulic fluid in plastic milk jugs ? #3
Safe.
Ditto that--- One note-- common sense prevails with putting cool fluid in there only..
Some jugs are thicker than others, so try to use the thickest you can..
J
   / Hydraulic fluid in plastic milk jugs ? #4
Also note that milk jugs are LDPE, which deteriorates with age. If they
are more than a year or two old, they may leak, even if stored indoors.
I have also seen them fracture if you drop them (empty) from more than
a couple feet.
I love to reuse my 5-qt engine oil containers and PETE gallon containers
that you buy fruit juice in. Unfortunately those are not acceptable by
our local recycling curb pickup service.
   / Hydraulic fluid in plastic milk jugs ? #5
I have 30 gallons of old hydro fluid to get rid of, but I don't want to loose my 55 gallon plastic barrel.
   / Hydraulic fluid in plastic milk jugs ? #6
It may just be illegal in some States to fill Milk Jugs with oil...... If you lived close to me, I accept waste oil... I heat one garage with a waste oil burner...
   / Hydraulic fluid in plastic milk jugs ? #7
What I have been using are the 5 gallon orange buckets sold by Home Depot with the sealing lids. The white 3 gallon buckets with sealing lids also sold by Home Depot just fit under my L39 for draining hydraulic fluid, engine oil, and antifreeze. I also use the large green Kitty Litter containers that have the wide opening and are sold by Costco. I've had them buried under 8 feet of snow for all winter long and after emptying them I've used them again for used engine oil, hydraulic fluid, and antifreeze.
Jim
   / Hydraulic fluid in plastic milk jugs ? #8
I save some of the empty 2.5 gallon SUDT CANS to use for that .
   / Hydraulic fluid in plastic milk jugs ? #9
Put it in smaller cans/jugs and take it to a place like Auto Zone.
I use empty 2.5 gallon SUDT CANS for that
   / Hydraulic fluid in plastic milk jugs ? #10
I have been using empty milk jugs for storing used hydraulic and engine oil for decades.
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
