hydraulic/fluid for bolens iseki 154 diesel tractor
   / hydraulic/fluid for bolens iseki 154 diesel tractor #1
nestor
bridge city,tx
i have a bolens iseki 154 diesel tractor. only one fluid is used for the gearcase and hydraulics.
what is that fluid?
   / hydraulic/fluid for bolens iseki 154 diesel tractor #2
You need about 13litres/3.5gallons & can use any of the following Castrol products:-
AGRI AS TRANS PLUS
or
AGRI MP PLUS
or
VMX80
or
Manual VMX80W
   / hydraulic/fluid for bolens iseki 154 diesel tractor #3
The product goes by various names in various brands but in general you are looking for Hy-Trans. Your local Tractor Supply or other lube diealer will know what it is.
   / hydraulic/fluid for bolens iseki 154 diesel tractor #4
some premium utf's may meet that spec. check the bottles.. etc.. walmart, tsc, etc... napa
thanks to all who have replied
after i posted i came across an on line owners manual that called for 80w gear oil in this application
could not print it out
will post if i can relocate
have to be certain about this
   / hydraulic/fluid for bolens iseki 154 diesel tractor #7
what kind of hyd pump does it have.
usually the only pumps handling gear oil are scotch yoke style.
sorry,but i don't know what scotch yoke is.
to the best of my knowledge there are only two addition points for organic fluids on this tractor.engine oil and the port under the seat where you add the fluid i am trying to identify.the large line running to the hyd. pump which i assume is the suction line,runs from the bottom of the transmission housing.
the fluid that is in it appears to be gear oil but it may not be the correct fluid
going to try to buy an owners manual
   / hydraulic/fluid for bolens iseki 154 diesel tractor #10
i'm assuming a piston pump orperhaps gear... vs vane??
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
