Hydraulic Fluid for Backhoe attachment on Mt 125
   / Hydraulic Fluid for Backhoe attachment on Mt 125 #1
traderfjp
Hendersonville, NC
LS MT240HE
Hi,
I was cleaning out a trench and my backhoe hit the side of a tree and tweaked the hydraulic line. I've lost a lot of fluid so I need to replace the hose and I wanted to change the hydraulic fluid. There are no LS dealers close to me. I went into TSC and they sell Travelers Premium hydraulic oil. It gets excellent reviews but after doing some research I saw a few posts of guys who had it analyzed and the antiwear additives is not great.
I'm wondering if I am over thinking this or should I just use the travelers or look for a synthetic fluid like Lucas makes. Any suggestions or insights would be helpful. Now I just have to find the drain plug.
   / Hydraulic Fluid for Backhoe attachment on Mt 125 #2
I had this debate a month ago after an inadvertent fluid change during the 50 hr service. The specs aren't very helpful, as it just says it must be ISO 48/64.
I ended up using John's Deere Hygard, which has very good reviews, and meets the standard. It's not the cheapest, though I see no reason to be penny wise and pound foolish, when it comes to fluids, and save $10-20 while risking a $20,000+ machine.
   / Hydraulic Fluid for Backhoe attachment on Mt 125 #3
If it's the factory LS BH, there is no separate tank. It runs off the main hydraulic system. If you lost fluid, your transmission is now low.
I used the Travellers, but I'm wondering about changing to Mobil 424.
   / Hydraulic Fluid for Backhoe attachment on Mt 125 #5
I was thinking of using Rotella HD Tractor Hydraulic & Transmission Fluid from Tractor Supply. It is GL-4 rated as recommended in the LS manual, but no mention of the ISO rating (Manual has ISO VG 32/46 listed). Opinions on the Rotella HD Tractor Hydraulic & Transmission Fluid?
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
