Hydraulic fluid fill
   / Hydraulic fluid fill #1
Alan57
South West Missouri
LS MT345E
Had the hydraulic fluid and filter change by an LS dealer. I noticed that the dipstick for the hydraulic fluid reads full to the top of the second notch on the stick. I thought it was supposed to be somewhere between the notches. should I be concerned? Should I drain some out? MT345.
   / Hydraulic fluid fill #2
How much/little/not at all have you run the tractor? Fully drained, your tractor has channels and cavities inside that may not be filled with fluid if you have not yet run the tractor. Take it for a slow, easy ride and operate it through the gears and hydraulic functions, then check oil level.
   / Hydraulic fluid fill #3
Your good. The top line is full and between the lines is safe. If I remember correctly it's about 2 quarts between the two lines.
   / Hydraulic fluid fill #4
The top mark will indicate full. The bottom mark is to indicate too low. Anywhere between the marks is good but even with the top mark is ideal.
   / Hydraulic fluid fill #5
When I check the hydraulic fluid level, I make sure all of the rams are in a closed position (not extended), then make sure the level is between the markings
   / Hydraulic fluid fill #6
If I check mine on my sloped driveway, it reads overfilled. Flat ground is just right. The slope is almost not noticeable, so just another thing to check.
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
