Hydraulic Fluid coming out Filler cap
   / Hydraulic Fluid coming out Filler cap #1
SailorBob
Mobile, AL
Yanmar YM1700
Hydraulic fluid has started coming out of the filler cap on the top of the transmission. I has just started doing this. The 3 point lift seems to be working fine. (YM1700) I saw a thread about this that said to check the vent tube under the seat. A dirt dobber may have clogged it up. My real question though is I want to remove it and make sure it is properly cleaned out. Does it just unscrew? I was thinking some vise grips or small pipe wrench would work? I did not want to damage it getting it off.
   / Hydraulic Fluid coming out Filler cap #2
Check the little inverted u shaped tube on the 3pt lift unit, top just behind the seat. If it is plugged It can cause this.
   / Hydraulic Fluid coming out Filler cap #3
"Does it just unscrew?"
Yep.
thanks guys
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
