Oil & Fuel Hydraulic fluid change on 5010 Mahindra
   / Hydraulic fluid change on 5010 Mahindra
Ok , according to manual which is not that clear there is one drain. So I remove hydraulic filter and hydrostatic transmission filter and fill with oil. Both run off same oil just filter differently?
   / Hydraulic fluid change on 5010 Mahindra #4
there should be a drain at the lowest point of the rear axle
   / Hydraulic fluid change on 5010 Mahindra #5
usually under the pto and yes both use universal hyd/trans fluid
   / Hydraulic fluid change on 5010 Mahindra #7
no worries be sure to fill the filters and oil then raise and lower the loader, 3point, drive forward and reverse, and turn your front tires back and forth a few times to bleed any air.. you will need to check again after all is done.. unless you put the exact spec of oil in the machine.
Thank you so much. You致e been a lot of help !
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
PALLET OF SINGLE & DOUBLE SINKS (A51244)
PALLET OF SINGLE &...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
