Oil & Fuel Hydraulic fluid change on 5010 Mahindra
   / Hydraulic fluid change on 5010 Mahindra
Ok , according to manual which is not that clear there is one drain. So I remove hydraulic filter and hydrostatic transmission filter and fill with oil. Both run off same oil just filter differently?
   / Hydraulic fluid change on 5010 Mahindra #4
there should be a drain at the lowest point of the rear axle
   / Hydraulic fluid change on 5010 Mahindra #5
usually under the pto and yes both use universal hyd/trans fluid
   / Hydraulic fluid change on 5010 Mahindra #7
no worries be sure to fill the filters and oil then raise and lower the loader, 3point, drive forward and reverse, and turn your front tires back and forth a few times to bleed any air.. you will need to check again after all is done.. unless you put the exact spec of oil in the machine.
Thank you so much. You致e been a lot of help !
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
UNUSED FUTURE 12' X 7' CONTAINER (A51244)
UNUSED FUTURE 12'...
Vermeer SC802 (A50322)
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
