Hydraulic Fluid change in Case 830 CK question
   / Hydraulic Fluid change in Case 830 CK question #1
marnun
Collegeville, PA
Case 830 CK
I recently purchased a Case 830 Comfort King. The hydraulic oil is milky so I was planning on changing it. I have located the three drain plugs so draining will be no problem. However, the screws on the operators platform are so rusted/worn that I can't get them out to access the fill plug. I would really like to avoid drilling out all these screws so my question is: Can I refill the hydraulic oil through the dipstick at the rear of the tractor? It seems logical to me but I am no tractor expert. Thanks a lot.
   / Hydraulic Fluid change in Case 830 CK question #2
I am not familiar with your model, but I would first verify that the rear and transmission uses a common sump (same fluid). If it doesnt and you drain the transmission.........putting oil in the dipstick hole will do nothing.
You also mentioned screw(s) on the operator platform. If there are more than one, I would assume that they are separate sumps. And either way, I would try to get the fill plugs OUT, because dipsticks usually are small and would take forever to get the appropriate amount of oil back in there.
   / Hydraulic Fluid change in Case 830 CK question #3
I don't remember having to remove a panel to add oil!
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2007 FORD F-250- LARIAT 4X4 (INOPERABLE) (A52472)
2007 FORD F-250-...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2017 PETERBILT 567...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
