Hydraulic fluid Bobcat M700
   / Hydraulic fluid Bobcat M700 #1
Anonymous Poster
Epic Contributor
I have acquired a Bobcat M700 (hydrostatic, 1970's vintage). A partially readable tag on the unit appears to state that the hydraulic system runs on Dexron, but it is presently filled with regular hydraulic/trans fluid.
Anybody know what is the right fluid for this unit?
   / Hydraulic fluid Bobcat M700 #2
Hi ya
I had a look at some oil links and could not find M700 but i did find all the bobcats run the same oil's ,none of them run dexron (ATF) the 2 oils i found are in NZ so ya will have to cross match them to USA oils
SHELL Rimula D 15W 40
BP Vanellus C6 Global
you could also look up oil com's in USA and see if they have a "lube ref" link on there web pages
catch ya
JD Kid
   / Hydraulic fluid Bobcat M700 #3
I have a Bobcat 500 which is pre1970 and the dealer told me to purchase Dexron or something that replaces Dexron.
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
