Hydraulic Flow question
/ Hydraulic Flow question #21
Thats what I am talking about.
I guess the MFG's arent clear. It could be either I guess. And it could even be different by MFG I suppose. I was just always under the impression that flow specs, speed specs, cycle times, etc was all measured at the engine RPM that delivers 540 PRO rpm, which is a little less than WOT.
Gotcha!
/ Hydraulic Flow question #22
PTO speed/eng rpm seems to be a simple matter of internal gearing, so the two can be all over the place.
My old FNH (1.3L) 1520's 540rpm PTO speed was @2250 and its redline 2600, per tach markings.
The new (1.7L) T-1520's 'PTO speed' is @2450, with "high idle" @2840 and "rated" @2600, per factory manual.
Not all engines make max torque at 'max' rpm and the rare one's torque at highest rpm can fall off such that max hp isn't there either. That said, whatever the 'pto rpm' of the engine is it should be at or near torque peak and 'rated' PTO hp must be taken with a grain of salt, esp with a 'light duty' CUT such as mine.
Anyway, I expect my hydro pump to put out max pressure at most speeds (say 1500rpm & up) with excesses controlled/diverted, but it's logical that flow is so nearly proportional to rpm.
This is way better than centrifugal water pumps that'll give you so many feet of head OR so many gpm (pick one) but would be darn lucky to give half their rated max for both at the same time. (Guess that's why hydro Q answers are so definitive and water-moving ones more like "try this & see what you get". ;) )
Oh, and thanks, guys for the depth of info. I haven't had so much fun with this topic since "Hydraulics #whatever" in college.
/ Hydraulic Flow question #23
Also, most skid steer equipment is designed to run at 3,000 PSI. not the 2200-2500 that most farm tractors supply.
I had to add a 3 point hydraulic pump and reservoir for my loader mounted blower for this reason. My system also stores 25 gal of low viscosity oil so it can cool off as it operates. If the hydraulic oil gets too hot it could fry your hyd pump.
/ Hydraulic Flow question #24
Just playing with numbers.
engine:
3000 rpm - .9 cu in pump - 12 GPM
2500 rpm - .9 cu in pump - 10 GPM
1300 rpm - .9 cu in pump - 5 GPM
There is a difference.
PTO rpm is that rpm that the engine has to turn to turn the PTO shaft at 540, or one of the other PTO speeds.
Max engine rpm is usually higher in all cases.
Andersen Fifth Wheel Hitch (A65579)
Andersen Fifth...
John Deere L100A Riding Mower (A65579)
John Deere L100A...
2022 EZ-GO ELITE...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
Farmhand CG 3000 Tub Grinder / Bale Processor (A66408)
Farmhand CG 3000...
