Hydraulic fittings loosen
   / Hydraulic fittings loosen #1
DKCDKC
Platinum Member
Staunton, VA
John Deere 3038E
I've had tractors pop a hydraulic line before, you just go get a new one. But, in 2012 I bought a smaller 3038 as a retirement unit. It's got 800 hours on it now, and no issues... Except every few years it seems to loosen one of the hydraulic line fittings and I get fluid everywhere. Never popped a line, and I routinely lightly tighten fittings. But had it do it again Monday - on the FEL and I wasn't even using it at the time. Rarely do I loose a significant amount of fluid before stopping it - but it's annoying. Am I doing something wrong?
   / Hydraulic fittings loosen #2
A drop of blue Loctite, once you clean the oil off, would probably help. I've had bolts and fitting like that, for no reason I could figure out, they would not stay tight. Maybe bad threads, odd vibration was the cause.
   / Hydraulic fittings loosen #3
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
