Hydraulic fittings for 1300D
   / Hydraulic fittings for 1300D #1
Hondo1
Western NY
YM1300D
I would like to know where I could find the right fittings for my 1300D. I need to cut the high pressure line coming out of the pump I need to weld/braze a 3/8ths fitting on each cut end. I have looked at www.hydraulicfittings.com , but can't figure out what I am looking at. Any help would be greatly appreciated so that I can finish this project.
Thanks
Hondo
   / Hydraulic fittings for 1300D #2
Mike, I can send you 3/8" hyd. fittings. I would use female fittings and run a die over your steel line, then screw the fitting on, then perhaps braze it in place. Gary J.
   / Hydraulic fittings for 1300D #3
Hondo,
The lines on the 1300D are probably a metric size. You can get metric compression and braze type fittings. I'm sure there is a way to adapt the metric to the 3/8.
Gary gave you an option, and I'm sure he has done it a time or 2 /forums/images/graemlins/grin.gif
   / Hydraulic fittings for 1300D #4
Weatherhead makes a 3/8 x compression adapter.
#C-516x8x12 with adapter ferrel to fit #7255x8. I get mine from a NAPA store in Mayfield KY. I have used them several times without a problem. Be sure and use a tubing cutter not a hack saw to cut your lines.
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2014 Dodge 5500 4X4 Bucket Truck (A53472)
2014 Dodge 5500...
ROME GK-14 LOT IDENTIFIER 118 (A53084)
ROME GK-14 LOT...
