Hydraulic fittings for 1300D
   / Hydraulic fittings for 1300D #1
Hondo1
Western NY
YM1300D
I would like to know where I could find the right fittings for my 1300D. I need to cut the high pressure line coming out of the pump I need to weld/braze a 3/8ths fitting on each cut end. I have looked at www.hydraulicfittings.com , but can't figure out what I am looking at. Any help would be greatly appreciated so that I can finish this project.
Hondo
   / Hydraulic fittings for 1300D #2
Mike, I can send you 3/8" hyd. fittings. I would use female fittings and run a die over your steel line, then screw the fitting on, then perhaps braze it in place. Gary J.
   / Hydraulic fittings for 1300D #3
Hondo,
The lines on the 1300D are probably a metric size. You can get metric compression and braze type fittings. I'm sure there is a way to adapt the metric to the 3/8.
Gary gave you an option, and I'm sure he has done it a time or 2 /forums/images/graemlins/grin.gif
   / Hydraulic fittings for 1300D #4
Weatherhead makes a 3/8 x compression adapter.
#C-516x8x12 with adapter ferrel to fit #7255x8. I get mine from a NAPA store in Mayfield KY. I have used them several times without a problem. Be sure and use a tubing cutter not a hack saw to cut your lines.
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
UNUSED CHERY INDUSTRIAL 7' - 10 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
