Hydraulic Fitting Question
/ Hydraulic Fitting Question #1
ETpilot
East Texas
Yesterday I made a mistake due to a dumb field mouse. I had my FEL with forks pointed down searching for wood debris in tall grass. I saw this mouse and sort of chased it along my route. Well the forks struck high ground and the bucket rolled to its limit causing the tractor to slow. I immediately raised the bucket and rolled it but I saw fluid spraying all over. I just shut down. Turns out one of the roll hoses rotated and it created a hole in the hose.
So I took the hose to NAPA and they made a new hose. I also kept the old hose. When I was ready to install, I checked one hose against the other and found the size of the new fitting different from original. Original fitting has a 3/8 opening. The new hose fitting has a 1/4 opening. This will, I imagine, cause a disparity between the 2 cylinders and may cause a problem due to flow rate. So I need opinions on this. New hose is not installed. I may have to take it back. The picture shows the different sizes.
/ Hydraulic Fitting Question #2
I suppose the right fitting on the picture is the old one, right? If you look deeper, the hole starts with 3/8", then it goes to 1/4". Just different brand fittings, machined slightly different. I think it'll be fine.
/ Hydraulic Fitting Question #3
The more immediate problem is the one on the left LOOKS like an ORFS fitting and the one on the right LOOKS like a JIC fitting.
/ Hydraulic Fitting Question #4
That's what I thought too, first one ORFS, second one a little harder to tell for sure, not enough contrast, but I still think JIC.
1/4" ORFS has the same size threads as 3/8" JIC
/ Hydraulic Fitting Question #5
Q
If that is the case, take the hose back and get one made using the correct fittings. On their dime.
/ Hydraulic Fitting Question #6
good eyes :thumbsup:
/ Hydraulic Fitting Question #8
With the reflection it’s hard to tell if they are the same type of fitting- they probably are. The flow difference between the two won’t make any difference on a CUT. Plus the old one has a step down in size that looks real close to the new one.....it’s negligible.
/ Hydraulic Fitting Question #9
I think its just the lighting. But as to the hole size, if they are indeed the same and both JIC fittings, there is no issues at all
Thanks for the replies. This hose is for the roll cylinder on a Ford 7210 loader. After reading the replies I took another closer look at the hoses. Definitely not an ORSF fitting. I had to look that one up. No O ring. New fitting is a flared fitting, JIC.
Using a transfer punch I measured the port opening. New fitting definitely 1/4 inch opening, hose is 3/8 inch. Old fitting has a 3/8 inch opening. Using the transfer punch a 19/64 inch was the only one I could get inside. Only a .0468 difference from 1/4 inch. Best I can figure. So flow wise I may be ok. In any event, I am taking the hose back and see what they say. I am probably ok with this hose.
/ Hydraulic Fitting Question #11
I am glad you got the correct fitting. I'll blame the camera flash on washing out detail on the first fitting.
/ Hydraulic Fitting Question #12
Agree the lighting is an issue looking at the pic...FWIW though only the male end of an ORFS fitting has an O-ring...
/ Hydraulic Fitting Question #13
That’s true, I took it that there was no oring at the other side of the connection. Glad the fitting is correct, I don’t see the porting as a problem at all.
Thanks all. Picture was not the best. But I learned about the other fitting. NAPA said I will not have a problem. That if I did encounter a problem, to bring the hose back. After all the review I feel better now. Going to install the hose now. Thanks.
1995 MACK RD690S T/A DUMP TRUCK (A64277)
1995 MACK RD690S...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
Loader Brackets (A65640)
Loader Brackets...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2008 New Holland T2420 (A62177)
2008 New Holland...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A59914)
2024 SILVERBACK...
