Pat's Easy Change Hydraulic Fitting Question
   / Hydraulic Fitting Question #1
deere5105
Veteran Member
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I need to swap the hose locations on the two shown in the picture. It doesn't seem there is a release for the fitting to pull loose. Have swapped before on my tractor, but this is someone else's. Seems I am missing something likely very simple...
Not sure how post got where it did. Here is pic.
   / Hydraulic Fitting Question #3
And what does this have to do with Pat's easy change???
Absolutely nothing. Not sure how to correct from mobile device where it originated and got too much mowing to do to stop and research.
   / Hydraulic Fitting Question #7
Just go to edit post and delete.
   / Hydraulic Fitting Question #8
Push in, then pull out, all in one quick motion. That should get them disconnected.
   / Hydraulic Fitting Question #10
They appear to be like the Kubota-style quick disconnects. Make sure all of the pressure is off of the fittings and then give them a yank. If they have even a little bit of pressure they aren't coming apart.
Sounds counter-intuitive but that is the way mine work.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2016 KUBOTA RTV-X900 UTV (A51243)
2016 KUBOTA...
