Loader Hydraulic Fitting Leaking
   / Hydraulic Fitting Leaking #1
SeaBiscut
Northeastern Pennsylvania
Ford 1715 and Kubota B3200
I have a Kubota B3200 with a LA504 loader. I forgot to let the pressure release from the loader when I disconnected it the other day. I could not reconnect the quick couplers to the machine when I tried to hook up the loader again. So I took apart two of the loader couplers to bleed off the pressure. Since I have done that the fittings that I took apart have a slow leak. I have applied Permatex Pipe Sealant but only waited about 5 hours before I applied hydraulic pressure to the fittings. Again they leaked. Do you think that I am over tightening the fittings? I did tighten them as much as I could. Today I removed the fittings, wiped them down, reapplied the permatex and only snugged the couplers to the hoses. Will this solve my leaking hoses? I am going to wait about 2 days or so for the pipe sealant to dry before I apply pressure to the fittings.
Thanks
   / Hydraulic Fitting Leaking #2
check the pressure rating of th Permatex sealant, you need a sealant that is good to at least 2000psi. If you are using a household (plumbing) sealant that is a problem.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A55973)
2019 John Deere...
2018 John Deere Z997R (A53317)
2018 John Deere...
man basket 72 '' (A56857)
man basket 72 ''...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
