Hydraulic filter for a Hinomoto E324
   / Hydraulic filter for a Hinomoto E324 #1
iloveketchup
Hinomoto E324
The only part number on it i can find is 554240. Anyone know what this tractor uses or a cross reference?
   / Hydraulic filter for a Hinomoto E324 #2
This is probably going to get you in the correct range. It's not rocket science, you just want to get a flter that is not too restrictive but gives good filtration and is the correct size. You have a 3S150 92ci Hino engine The MF1035 has a MS150 92ci Hino engine and I'm sure similar (maybe the same) hydro pump/capacities/filtration requirements, etc.....in other words, sometimes you just don't have anything else to go by other than educated guess/speculation, which is what we've discussed to be a common problem with these tractors from day one. Now someone more familiar with your tractor may jump in and be able to tell you the exact filter # for every filter manufacturer that is a match for the 324 but this is what I got off the WIX site by looking at what works for Masseys/what might be closest to the 324. You can cross reference the WIX numbers to other brands online if you want to use something else, I just like WIX filters.
WIX Filters : Filter Look-Up
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
ASV Posi Tool Backhoe Quick Attach (A51573)
ASV Posi Tool...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
