mrtwister
Bronze Member
I intend to swap out my old hydraulic filter for a new one without first draining the hydraulic fluid from the tractor...has anyone ever done this?...the fluid looks good however I feel the filter should at least be changed to eliminate any possible contaminants in the system.....is there an issue with hydro fluid gushing out when the old filter is removed before installing the new one or is the fluid simply resting at the bottom of the engine/transmission below filter level? :confused2: thanks...twister
