Hydraulic fill for ford 2120?
   / Hydraulic fill for ford 2120? #1
BUBBLEHEAD1
Alexandria, NJ
New Holland 2120
I bought this Ford 3rd hand and do not have manual for it. I blew a hydraulic line moving the snow around here in NJ and replaced. Now I want to fill up any that I lost. Problem is, I do not know where to add the oil? It is a 1988 2120.
Thank you.
   / Hydraulic fill for ford 2120? #2
Attached is a scan from the owners manual. Fill is at rear housing behind seat, dipstick on floor on tranny hump.
Jim
  • 2120 hydraulic check, fill.pdf
   / Hydraulic fill for ford 2120? #3
You can get an owners manual cheap from FarmManualsFree, six bucks or so
Jim
   / Hydraulic fill for ford 2120? #5
If your hydraulic oil is relatively new and clear, it is difficult to see the level on the dipstick. You can cut a long stick, or something clean that is a dark color that will show a wet oil line, insert it in the dipstick port below the steering wheel and match up the wetted stick distance from the top of the casing with the actual metal dipstick. The wet mark point should be a distance below your fingers matching the distance to the crosshatched portion below the top of the metal dipstick shaft.
45014 (A48082)
45014 (A48082)
2012 NORMAN POWER SYSTEMS 100KW GENERATOR (A48992)
2012 NORMAN POWER...
More info coming soon! (A48081)
More info coming...
FIFTH WHEEL HITCHES W/FENDERS (A48992)
FIFTH WHEEL...
2016 Chevrolet Traverse 2LT SUV (A48082)
2016 Chevrolet...
2017 HINO 258A (A48992)
2017 HINO 258A...
