hydraulic dump trailers
/ hydraulic dump trailers #21
Tonight I ran over to a bud's with the tractor and pulled some red tip photenia stumps with the home made backhoe attachment I made for my tractor.
There is such a feeling of accomplishment when the tractor reacts just right and you realize you had part and parcel of it and it was all instinct.
/ hydraulic dump trailers #22
Last night at a friend's was discussing your idea for a side dump trailer, the mechanism was throwing my brain off. He took me to the outback and showed me his old '55 dump truck. The piston and pump were frame mounted, then the piston pushed a set of rollers engaging a pair of bellcranks, the bellcranks in turn doing the dumping. Simple.. or is it? He still uses his dump, so no I can't have the parts.
/ hydraulic dump trailers #23
Add this one to your list.
Sands Welding
Albany MN
877 845-2407
Their dumps trailers look solid without alot of metal. Means you can haul more.
Frame is built with 4x6 tubing. Drop axles lower the height. Tail gate is multi position opening.
Ray
