Hydraulic Driven Snowblowers
/ Hydraulic Driven Snowblowers #11
I would love to get a front PTO snowblower to save my neck and back. The only problem is that you lose the FEL. Around here we can get some pretty wicked blizzards and the drifts can support the tractor! If I use the blower it rides right up and over. Even the float on the FEL will ride up and over. Have to really dig at them. So I guess it is a sore neck for me. Was toying with an idea for large mirrors.
/ Hydraulic Driven Snowblowers #12
We get pretty big drifts here but no problem for the new blowers.Use drirft,power up or down.As Isaid earlier agreat blower and if too big a snow just slow down just a bit and it will chew its way through.Try one you,ll love it.
/ Hydraulic Driven Snowblowers #13
Its not a problem to chew through the thickness of the drift. But the blower rides up and over them. Not enough cutting/down force on the blower edge.
/ Hydraulic Driven Snowblowers #14
The frount mount blower gives you the same downforce you get with your loader,I can lift the tires off the ground so its not an issue.Hope that helps.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2021 Caterpillar 299D3 (A60462)
2021 Caterpillar...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
Iranch IRGC40 (A60463)
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
