Hydraulic drift
/ Hydraulic drift #1
yotehunter66
Bronze Member
Clayton, Mi
1983 Simplicity 9518,1948 Ford 8N , 2013 Yanmar EX3200
Got a Bradley 6LD hooked to my EX3200. Seems that all my cylinders drift on it. I wouldn't think all the cylinders need rebuilt. Is there one item that could be leaking by that would cause this?
/ Hydraulic drift #2
could be a worn control valve......is the Hyd oil clean?
You should use a gauge and troubleshoot before pulling stuff apart
/ Hydraulic drift
Clean oil and filters. I've only replaced two worn hoses on it. Just seems odd that all the cylinders would leak down on it. Thought maybe a check valve or something on the hoe could be leaking by.
/ Hydraulic drift #4
If the cylinders are in series only one of them needs to leak by the seals to make it look like both/all are bad.
/ Hydraulic drift
Oh. Well I know one that needs rebuilt. Thanks.
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59912)
2020 KENWORTH T680...
