Hydraulic Drift - Since Tranny Oil Change
   / Hydraulic Drift - Since Tranny Oil Change #1
Windward
Belgium
Cub Cadet SC2400 (Yanmar)
Last fall I bought a used Cub Cadet SC2400 with 80 hours on it. I have used it around the place for some small projects and I never noticed the hydraulics slipping at all. A few weeks ago I changed the transmission oil and filter before starting a large patio project. Since that time I have moved about 40 yards of dirt and backfilled about 10 yards of #1 stone. While doing the stone, I noticed that my bucket was slowly dropping (I think this is called "drift").
I used Case Akcela Hy-Tran UltraAction and follow all the instructions in the manual, including the start up procedure post oil change. The dealership is the one who recommended the Case oil and I called the manufacturer and they confirmed that the Cub Cadet was spec'ed for that oil.
I suspect I have a leaky seal or a leaky control valve. Is there an easy way to isolate where my problem may be?
Is this something I can continue to use as long as the drop is slow? Or am I going to cause more damage than if I were to fix it now?
As you can tell I am new to hydraulics and I appreciate all your input.
Thanks
Matt
   / Hydraulic Drift - Since Tranny Oil Change #2
Some drift or leak down is normal, if it becomes excessive enough to bother your use I would repair it. Not much chance of damage if the fluid isn't leaking out externally.
   / Hydraulic Drift - Since Tranny Oil Change #3
It's possible you now have air in the system. There could be a bleeder bolt near (or on) your hydraulic pump housing. Check the manual for it... It is listed in my manual. I actually have two, one for the main hydraulic pump, and one for the steering pump.
I do have a minor amount of oil leaking from the cylinders.....just enough to gather some dust....not enough to cause a drip.
I checked my book and could not find any info about a bleeder valve. And when I look at the valve itself, nothing jumps out at me as a bleeder valve.
I suppose I will just live with it til it get's bad enough for me to take it in.
Thanks!
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
