Hydraulic distributor. Am I correct?
   / Hydraulic distributor. Am I correct? #1
ArtMech
Platinum Member
Lithuania, EU
Present: 2003 Kubota M9000 DTF; 2001 Kubota B72. Sold: 1985 Kubota L2202
This is a distributor which I've got from metal scrap. Don't know what machine it is from. All I know it's made in Sweden.
I have only one port of remote valve on a tractor. What if I'll attach this distributor additionally to have many more ports?
The thoughts are as follows:
1. I guess there are 3 ports to be able to connect 3 double action cylinders.
2. There is 1 port to be able to connect 1 single action cylinder.
3. 1 input connection (under pressure)?
4. 1 output connection (to a tank)?
Am I correct?
Never mind about micro switches at the bottom.
   / Hydraulic distributor. Am I correct? #2
What type hyd system do yu have ?
Open center hyd system with all valve sin series.
Closed center with all valve in parallel.
Hybrid with some closed and some open center.
I also do not see a relief valve.
One spool is set up for SA.
You have some plugs in ports on the other side of the valve. Is one of them marked PB.
Mark where you think the P and T is.
You can use air pressure to verify flow.
I think larger diameter goes to tank.
I can't answer the other questions. Needs to find out somehow.
Thanks for reminder to use air flow to verify how it goes. I have no possibility to find mark PB right now. I'll do it later.
   / Hydraulic distributor. Am I correct? #4
Its a Parker valve, so you should be able to contact Parker to find out the specs on it.
If its open center, you will always have flow from the pressure port to the tank port and one of the plugs on the end away from the two ports may come out for a power beyond port.
Aaron Z
   / Hydraulic distributor. Am I correct? #5
Are any of the ports marked? P, T, PB, etc
I'm not in a farm right now. I'll check it when I'll be there.
Thank you fellows J_J and aczlan for your help.
   / Hydraulic distributor. Am I correct? #7
It looks to me like the port you have marked as Pressure has a P in the casting next to it and the one you have marked as Tank has some other letter (a Y perhaps?) in the casting. At the far end, there is a letter by the plug on the end, but the camera angle isnt right to pick it out.
Aaron Z
   / Hydraulic distributor. Am I correct? #8
If your valve is an open center valve, and IN neutral, when you blow air into the IN port, air should exit the tank port.
If the valve is a closed center valve, in neutral, when you blow air into the IN port, no air should flow out any port.
Most open center valves will have a relief valve, and I don't see one.
   / Hydraulic distributor. Am I correct? #10
Maybe, but is could also be a no-relief plug which is sometimes used for closed center valves.
Galvanized steel Fence (A53424)
Galvanized steel...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2023 Toyota Rav4 AWD SUV (A55853)
2023 Toyota Rav4...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
