Hydraulic detent
/ Hydraulic detent #1
psj12
Platinum Member
Short OK
KIOTI 551
Has anyone removed the detents from your hydraulic remote valves? How did you do it? Was operation affected?
/ Hydraulic detent #2
It's been done. I believe there was a recent thread here about it on a CK or possibly a DK series. It will not affect function except that it will make it necessary to hold the lever to choose flow or no flow from the remote.
/ Hydraulic detent #3
The dealer did mine, he returned them to me in a bag. He was very cautious about warning me about the dangers. As I did not have a need to run a motor or splitter, I let him take them out. But I don't know how involved it was.
/ Hydraulic detent #4
They're Youtube videos showing how it's done on a DK-40. It requires removing the seat and metal plate it attaches to, then removing the bolthead in the valve which holds 3-4 detent balls and a spring. Then reassembly and done. No more detented valve.
/ Hydraulic detent #5
http://www.princehyd.com/Portals/0/valves/LvManual.pdf
Look at this PDF.
It is a Prince valve, but you will see the springs and balls that fit in a groove.
Just remove the spring and balls, and reattach the can and you will be with out detent.
Throw a small magnet in the bag to keep all the balls and springs together for later use.
/ Hydraulic detent #6
I have a front snow plow and redirect the rear remotes to the front. I did mine and it is not hard to do. There are threads on here that document how to do it. And yes the search function leaves a lot to be desired.
213138 (A64276)
213138 (A64276)
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2014 Ford Expedition SUV (A64557)
2014 Ford...
1062 (A63291)
1062 (A63291)
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
