Hydraulic detent
   / Hydraulic detent #1
psj12
Platinum Member
Short OK
KIOTI 551
Has anyone removed the detents from your hydraulic remote valves? How did you do it? Was operation affected?
   / Hydraulic detent #2
It's been done. I believe there was a recent thread here about it on a CK or possibly a DK series. It will not affect function except that it will make it necessary to hold the lever to choose flow or no flow from the remote.
   / Hydraulic detent #3
The dealer did mine, he returned them to me in a bag. He was very cautious about warning me about the dangers. As I did not have a need to run a motor or splitter, I let him take them out. But I don't know how involved it was.
   / Hydraulic detent #4
They're Youtube videos showing how it's done on a DK-40. It requires removing the seat and metal plate it attaches to, then removing the bolthead in the valve which holds 3-4 detent balls and a spring. Then reassembly and done. No more detented valve.
   / Hydraulic detent #5
http://www.princehyd.com/Portals/0/valves/LvManual.pdf
Look at this PDF.
It is a Prince valve, but you will see the springs and balls that fit in a groove.
Just remove the spring and balls, and reattach the can and you will be with out detent.
Throw a small magnet in the bag to keep all the balls and springs together for later use.
   / Hydraulic detent #6
I have a front snow plow and redirect the rear remotes to the front. I did mine and it is not hard to do. There are threads on here that document how to do it. And yes the search function leaves a lot to be desired.
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
Two Post Car Lift (A50120)
Two Post Car Lift...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
