Hydraulic design
   / Hydraulic design
Leejohn- I did consider a mechanical hookup but 1 don't have the room for the gearbox and I would need a a transmission for forward/reverse. I agree there are limits for the pump but as this thing only had about a 5hp electric motor. Also this is for work around the ranch and speed isn't an issue. I've still got some calculations on the gear ratio of the differencial etc.
   / Hydraulic design #12
   / Hydraulic design
Yep, looked at those also and I wish I could go that way but I still run into the problem of a vertical shaft motor, then the transmissision, then the right angle gearbox. It would work if I had the vertical room to mount everything. I've got maybe 12in. from the driveshaft to the bottom of the seat. More mechanical problems than I want to tackle. The only other method that's practical is going electric. But the cost of batteries is prohibitive.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2007 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2007 STERLING...
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
