Hydraulic deck lift on a ZD1211
   / Hydraulic deck lift on a ZD1211 #1
Rob in Ontario
Kubota L4240
Looking forward to getting my new ZD1211 (60" SD deck) this week. Anxious even more because I ordered it with the Air Ride seat from the ZD1511. I'm currently using a '08 Toro ZMaster diesel w/52".
New to Kubotas with the hydraulic deck lift. On my Toro I tend to raise and lower the deck (manual) up to say 10-12 times per mow to get over some raised roots or crossing the gravel driveway etc.
Is there a concern if I use the Hydro lift in the same way? Can you use it too much?
Thanks in advance
Rob
   / Hydraulic deck lift on a ZD1211 #2
Nah use it much as needed.
it sure is handy & fast.
I never completely stop.
you'll love the machine.
the ZD has a real transmission & no silly pumps at the wheels + a shaft driven deck 💪
Fast blade tip speed
The pivoting front axle is a nice feature for uneven ground & rides better
   / Hydraulic deck lift on a ZD1211 #3
If you use it too much your grass will look funny and not very even height!
   / Hydraulic deck lift on a ZD1211 #4
I use mine that many times without an issue.
Thanks for the replies. Again its really just in spots I know the tree roots are too high, and gravel areas after my son tears up the driveway with his quad (argh)
   / Hydraulic deck lift on a ZD1211 #6
What height will you be mowing at ?
the #’s on dial knob are only for reference. Their not actual blade height btw
   / Hydraulic deck lift on a ZD1211 #7
I raise and lower mine frequently for roots and cresting hills to avoid scalping. Both of my ZD mower deck lifts raise way too fast for my taste, so I may look into somehow using a restrictor to slow it down.
   / Hydraulic deck lift on a ZD1211 #8
Not an issue raising & lowering the deck frequently. I raise & lower mine dozens of times each mowing.
I agree that the raise & lower functions are very fast. All you need to do is quickly tap the up or down to raise or lower but it is nice when you hit something.
90cummins
   / Hydraulic deck lift on a ZD1211 #9
Looking forward to getting my new ZD1211 (60" SD deck) this week. Anxious even more because I ordered it with the Air Ride seat from the ZD1511 Rob
Did you get the ZD1211 ?
air seat ?
   / Hydraulic deck lift on a ZD1211 #10
I have a zd21 and use it religiously. It's standard hydraulics, there should be no issue, it's no more complicated than tilting your bucket on your tractor. I don't' know about yours but the zd21 seat adjusted properly for my weight is a dream.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
