Hydraulic cylinders leaking
   / Hydraulic cylinders leaking #1
cyberflyrg
Buford GA
Kioti DK45 4x4, Ford 3000
All four cylinders on my Yanmar 2700L front end loader are leaking around the seals. What type of packing/seals are in these cylinders? This is the factory loader that came with the tractor. thanks ron:(
   / Hydraulic cylinders leaking #2
The factory never made a loader. Yanmar had a loader made that they sold in the US under their name for the domestically sold Yanmar models. Are you saying the loader is a 2700L, or the tractor is a YM2700?
   / Hydraulic cylinders leaking #3
hi ron, i will say that if the loader is a Bulldog or V-Tec brand, parts will be a problem from most suppliers.
Do you have the Manufacturer's name or a model number?
What I would do to repair No-Name Cylinders is:
→ remove the cylinders and disassemble them to access the warn out part.
→ bring the removed seal and the cylinder parts to a quality parts house (hydraulic or bearing supplier, even a NAPA will help get the right seals by mic'ing components for the correct replacements)
→ when disassembled you may find o'rings are all that are needed, units need to be taken apart to find out
→ if the leak is not to bad, delay repair, for when the tractor repairs down time won't interfere with needs so much.
YM2700 is a gray market tractor, the loader came from Japan with the tractor. It has all japanese markings and writing on it, so it may not be a yanmar, but it aint a bull dog either.:(
Thanks rhett, thats what I started doing tonight. I removed the cylinders and tomorrow Ill dig into them to find out what is leaking. I have a NAPA store close by and if they cant match them up, Ill go into to Atlanta and find a hydraulic company that can help me with the seals. The rams are nice and shiney with no rust or corrosion and also work great. Very strong loader, just leaks like a basket. I assume they are all dried out from sitting and lack of use. thanks ron
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
2012 FRAC TANK (A53843)
2012 FRAC TANK...
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
