Hydraulic cylinder ?'s
   / Hydraulic cylinder ?'s #1
dodge85rc
MN
I am adding a separate hydraulic cylinder to lift the sleeve hitch on my Case GT. I'd like to use what I have on hand as much as possible to keep the costs down. I am going to mount it so that when the cylinder extends it is going straight up and down to lift the hitch. I have a cylinder that has a 5 inch stroke just like what I want but it only has a 5/8ths rod. Seems a little light to me but I tend to overbuild everything. Realistically all I will ever lift with this sleeve hitch is about 250 lbs max because that is getting to be a lot of weight hanging off of the back end. Would that cylinder work in this application?
   / Hydraulic cylinder ?'s #2
It will probably work as long as there is no side load on the cyl shaft.
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
Genie GTH-644 (A50490)
2023 G Bar K Goose Neck Flat Bed (A53473)
2023 G Bar K Goose...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
