Hydraulic cylinder repair ??
   / Hydraulic cylinder repair ?? #1
Billy_S
Central IL
Kubota BX2230, JD 400, AC 190XT
I took the hydraulic cylinder off of the loader for my BX2230. This was the center cylinder that controls the dump of the bucket. It was leaking.
I took it into the dealer, who repaired it in 15 minutes, under warranty. My question is, when I put the cylinder back on, is there anything I need to be concerned about? Do I need to somehow bleed the system or do I just work the joystick and things will start working, once the cylinder gets pressurized?
   / Hydraulic cylinder repair ?? #2
I don't have a PHD, but I believe the latter, just work the stick repeatedly.
Check your fluid level.
   / Hydraulic cylinder repair ?? #3
Just work the joystick so that the cylinder cycles completely a few times. It will self bleed.
Thanks, gentlemen.
   / Hydraulic cylinder repair ?? #5
And recheck that fluid level...
David from jax
   / Hydraulic cylinder repair ?? #6
Nice post...Thanks for the info.
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
ROBINSON CENTRIFUGE (A53843)
ROBINSON...
