Hydraulic cylinder question...
/ Hydraulic cylinder question... #1
mrcaptainbob
Platinum Member
Jackson County, Michigan
Bolens HT-20
The plate on the cylinder reads: HYM-N2R-4x18 and 1E 7405-595-2B. How can I find the brand and the max PSI for it? The end plates are at least an inch thick and the tie bolts are 3/8.
/ Hydraulic cylinder question... #2
If it has tie bolts it is most likley not rated for over 3000 psi that would be a bout maxium
Thanks, Dirthog. I did actuall measurements t'day and found the end caps are a full two inches and the tie bolts are 5/8". That may not make any diff, If I can use 3K PSI, that would work for me, too. This is on an old log splitter I 'inherited'. Everything on it is OLD! All controls and pump and such are Vickers or Vickers Sperry. Next need to dig up info on that pump. Thanks for the info.
1979 Donahue Dump Trailer (A66285)
1979 Donahue Dump...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
Exmark C2-96 (A64127)
Air Compressor (A64127)
Air Compressor...
12ft T/A Flatbed Utility Trailer (A64557)
12ft T/A Flatbed...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
